But I just watched an episode of Mythbusters.
They did some tests in fluid dynamics where they were testing if the dimples on a golf ball reduced drag; would they reduce the drag on a car. (and it did by the way…) Check it out on discoverys website
So I got to thinking, if it works on a car. How would it work on the bottom of a boat. It is supposed to reduce drag and wake.
Anyone out there have a sacrificial running boat that they wanna experiment on?
I was just watching that episode too. I can't believe, even with the extra weight of the clay, the car still got 11% better gas mileage. I don't see any reason why it would not work for a boat as well.
Unfortunately I have only one boat and I don't plan on sacrificing it for science sake any time soon.
There are boats currently being made with dimpled hulls, there were also boats that were made with different types of texture on the hulls. I don't have any info on what worked and what didn't though.
one a 100% displacement hull it would make a bigger difference, but on planing hulls you have some different things to deal with.
sort of like waxing. it makes a very small difference, but waxing actually slows a boat down! i've seen the effect personally on a pwc, but it apparently is a big deal in the competition rowing/sailing world.
Coincidentally, I was watching Time Warp last night and one of the experiments they showed was a pair of cue balls dropped into a fish tank. One ball was plain, was was "waxed" with a microscopic layer of water repellent. The water repellent had the same water beading affect that wax has. When dropped from the seam height, the "waxed" ball created a much bigger splash and decelerated noticibly faster than the plain ball. The water repellent really increased the hydrodynamic drag. I assume wax would as well.
I watched that too. That is so crazy, I would have thoght water repelent would have made it easier to cut through the water.
I would love to know the science behind those dimples.
...but I think I remember back from a college course I took, it has something to do with turbulence. A dimpled golf ball travels through the air with less turbulence then a plain ball. The dimples somehow "organizes" the airflow around the ball. Turbulence behind an object can create a pulling or suction type force that can work against it. Maybe somebody with an aeronautical engineering background can enlighten us.
__________________
2007 Stingray 180RX VP 3.0 GLP-E SX-A Pulled by a 2007 Chevy Tahoe 5.3L "if you're going to be stupid, you'd better be tough"
Well in a similar fashion, many aircraft (especially airliners) have "vortex generators" in strategic places on the wings/rudders/elevators. These are usually an inch or two long and look sort of like shark fins. The point of using them on an otherwise-smooth wing is because at slower speeds it organizes the air stream to keep it from separating from the wing surface, which allows much better control and slow airspeeds.
I'm sure the dimples serve a similar effect on golf balls where it reduces drag by maintaining flow across the surface with little air pcokets in the dimples. The difference in the boating world may come down to the cost of producing a hull with dimples and whether or not you are traveling at a speed fast enough to take advantage of the dimples as pressure zones. It would likely only be usful to dimple the back half of the hull for most boats (back 12" for those crazy bass boats).
__________________
1976 Mark Twain 200VBR w/351 233HP "Heart & Soul"
Ever wonder why fish scales are overlayed toward the rear? Same principle as dimples, vortex generators, and a hail damaged auto. I allows them to slip through the water at faster speeds while expending less energy in the process.
Reggie Fountain (Fountain boats) once tested a hull for a speed record and they pulled the boat and used a drill to dimple portions of the hull to create turbulence which helled the top end.
Look at a shark's skin and there is no doubt about their ability for speed.
__________________ "When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
I used to have a contact at NASA and had a few email exchanges about this sort of thing with him. 3M used to make an adhesive sheet with small grooves accurately machined in, this technology is call "riblets". These 'grooves' are about 0.001 to 0.005 inches thick. Strategically placed on aircraft it can reduce drag by 4 - 8%.
It's also been used on boats. Stars and Stripes won the America's Cup using this technology in 1987. I heard a while ago that 3M quit making this stuff, it was expensive and not much of a market. Apparently to be effective the machining has to be pretty accurate, not something we could do at home on our hulls.
I will see if my brother, a naval architect/engineer can provide a helpful link or brief summary of the principles involved. If I remember correctly, a rougher surface may help by creating small eddies or turbulence which actually reduces the impact on the laminar flow of the boundary layers that become "stacked up" by the disturbance created as the hull/wing flows through the fluid in question. A good diagram would truly be worth a thousand words here as I'm not explaining it very well. Of course I am in finance, not engineering.
So what if we use scales on the bottom of a boat instead of dimples?
That would be easier to pull off on a boat. I wonder if it would do the same thing?
It works on people too! Those fancy one piece "sharkskin" swimsuits used in the olympics last year have a rough texture. The swimmers get reproducibly faster times in suits.
I've also hear boat racers sand their hulls, but I have no first hand knowledge of this.
The dimples make the boundary layer more turbulent and also thinner than a smooth laminar flow. Also, because the boundary layer is turbulent, there is less velocity difference between the boundary layer and the slip stream going by the layer thus reducing drag.
__________________ "Common sense is not very common"
1998 Wellcraft Eclipse 24 Cuddy
Volvo Pental Duo-Prop 7.4L "LK"
Yes they do, taking the gloss off the gel coat makes the boat faster. Sanding introduces more microscopic grooves which produces the turbulent boundary layer.
Saw it all the time back when I used to race catamarans. I didn't do it becuase there were so many other factors that made me lose races other than something that sanding could help.
After reading all these posts, I have to ask if someone has experimented using the dimpled surface on props??? Or would that work the opposite reducing the prop's bite in the water??
Mike
