Re: Loose Bunk Board fasteners....what does this require??
I redid mine in the parking lot at the ramp on a quiet day. I beached the boat and did it right in the parking lot. I cut the bunks to length at home and used a battery powered drill to drill the holes. In my case, the bunks were through bolted with carriage bolts, so I was able to re-use those. Instead of carpet, I used bunk slides. I figure that the carpet just keeps everything wet and ready to rot. It took a total of about an hour.
If you use carpet, you might want to attach the carpet before you leave home. Use either stainless or monel staples.
One more very important thing. If your boat is aluminum, then DON"T use pressure treated. PT lumber will eat holes through your aluminum. Also, it requires special hardware in order not to have galvaninc issues. In fact, it has issues anytime it has contact with bare metal, so I would just avoid it altogether. If you want rot resistance, you might try to get white cedar or redwood instead of just pine. My original bunks appeared to be just ordinary pine, and they lasted for almost twenty years and then the reason that I replaced them was because one was split, not because of rot.
TerryMSU
