  #1
Old October 21st, 2009, 01:01 AM
Rosco 11 Rosco 11 is offline
Default 2002 Yamaha 30hp knocking
Hi all,
I have just bought a 30 DMH Yamaha, and am in the process of ironing out a few bugs in it.
Have put a new water pump kit in, new plugs and t-stat as well.
I am stumped with a knocking that is in the engine. On the muffs, it seems to only knock as the revs are coming down, rather than going up. It seemed to do it more often if I reduced the revs suddenly.
The knocking is very hard to describe in words . . .but it seems like the driveshaft is trying to engage itself back into an already turning spline. It's hard to say if the noise is coming from the powerhead, or the lower unit.
I took it for a test run today, and found that the knock is worse under load. Whenever I tried to go more than say 1500rpm, the knock was there, and the motor even stalled a couple of times as the knock was happening.
Any suggestions as to where I should start ? I have a manual and average mechanical skills ( mostly learnt from iboats ! )
All help gladly appreciated. Thanks . . .
  #2
Old October 21st, 2009, 01:10 AM
sigma sigma is offline
Default Re: 2002 Yamaha 30hp knocking
Since it not only happens in gear but out of gear on the muffs I would say either a loose flywheel or a crank bearing? Possibly a bearing on the lower unit right at the engine like a drive shaft bearing
__________________
Sigma
  #3
Old October 21st, 2009, 01:57 AM
moonfish moonfish is offline
If there isn't enough fuel a motor will cough. You might call the same sound a knock although the motorheads wouldn't. It can be kind of violent.
  #4
Old October 21st, 2009, 06:28 PM
Thanks Sigma and Moonfish for your replies.
I'm leaning towards the flywheel at this stage ( makes sense, fits the symptoms and is pretty easy for me to look at ). I will grab the torque wrench and have a discussion with it later today.
I also suspected the pinion bearing/nut . . but I discounted that by removing the lower unit and starting it ( with the water hose straight onto the tube) . . and it still made the knock/clunk sound. Didn't seem to do it as much, but still did it.
So the lower unit doesn't seem to be the guilty party here.
Thanks again for the replies . . I will let you know how the flywheel goes.
In the meantime, any more suggestions ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 30HP 2002 manual tilt help Rosco 11 Yamaha & Suzuki Outboards 0 October 1st, 2009 05:29 AM
2002 5.0 V8 Mercruizer, knocking engine noise? BoatMyAssOff Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 14 January 14th, 2009 07:45 PM
Overheating of 2002 honda 30hp motor pmoles Honda & Tohatsu/Nissan Outboards 3 May 30th, 2008 06:47 AM
96 30hp stator knocking? brunolund Yamaha & Suzuki Outboards 4 May 17th, 2008 08:19 PM
2002 Yamaha 2-stroke 30hp specs and opinions?? james082273 Yamaha & Suzuki Outboards 3 December 4th, 2003 04:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
