The steering console is not an Alumacraft accessory but is an after market model that was installed when the boat was new. It is a Helm-Rite with an Attwood steering wheel. It can be installed on either side of the boat, the original owner installed it on the left side. The Attwood steering wheel had many cracks. I used a drimmel to ground a 1/8 inch beveled groove in each crack and filled them with Waterweld epoxy putty, sanded, primed and painted with automotive enamel paint matching Johnson white. The round plastic circle above the steering pulley is the horn button. I added a vintage compass and speedometer. http://forums.iboats.com/attachment....d=12560924 05 http://forums.iboats.com/attachment....d=12560924 15
Reason: typo
Here is the anchor winch. Is was made by D.E. Rice Company. The winch has an internal brake drum that locks the anchor's position. I has 100 ft. of stainless steel aircraft cable routed through several pulleys. I found the winch in the original box, but it is missing the anchor. I am in search of an original anchor for this winch, meanwhile I am modifying a mushroom anchor so it will seat itself properly into the flange of the bow mount. http://forums.iboats.com/attachment....d=12560937 92 http://forums.iboats.com/attachment....d=12560938 05
The 35 Johnson is a long shaft motor, I built an adjustable jack plate that raises it about 5.5 inches and sets it back about 6.5 inches. The jack plate plans are from this site http://www.dillon-racing.com/jackplate/index.htm.The boat really flies with this setup, I am still fine tuning motor height and testing props, it currently has a 10.5 X 11 and needs more pitch for top end. The stabilizer keeps the bow flat at take off and at top speed it is very stable even during hard turns. I am very pleased with the performance and handling. Before restoring the motor, I took tracings of the original cowl decals which were orange and black, and after painting applied new two tone blue decals that I recreated in Illustrator on my computer and had a sign shop cut from vinyl. http://forums.iboats.com/attachment....d=12560944 61 http://forums.iboats.com/attachment....d=12560944 76 http://forums.iboats.com/attachment....d=12560944 94
