  #1
Old October 19th, 2009, 11:26 PM
skibarefooter skibarefooter is offline
Default 1986 Mercury 75 hp 4 cylinder
I am a newby to outboards and to there problems. I have spent the last month reading and studying about them in the repair manual I have. My motor when I am starting will fire once and the starter will keep spining but the motor will disengage from it. It is slow to start this way. Once started it seems to run fine and cranks from that point ok. Is it a timing issue which I have not checked. Please help
  #2
Old October 20th, 2009, 02:09 AM
jake505 jake505 is offline
Default Re: 1986 Mercury 75 hp 4 cylinder
Sounds like a fuel problem more than a timing problem to me. If it were the timing it would be constant but since it is only when u first start it I would say fuel. make sure you prime it real good before starting. if you continuously prime it and it never gets firm it could be the primer bulb is bad or you have a leak some where like the fuel pumps. most likely your primer bulb though sounds like its not getting enough fuel on the first start then once it does start its primed up and fine
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Mercury inline 6 no spark #3 cylinder frb Mercury & Mariner Outboards 1 June 5th, 2009 11:05 PM
1986 Johnson 70 HP Cylinder 1 Bog Down Seadoomanls Johnson & Evinrude Outboards 23 May 13th, 2009 12:27 AM
1986 mercury outboard 6 cylinder, 90hp....hard to start, doesnt idle in gear Edison Mercury & Mariner Outboards 10 November 1st, 2007 09:04 PM
1986 Mercruiser 170 4 cylinder Packers4ever Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 June 27th, 2007 05:29 PM
1986 90 HP Mercury in-line 6 cylinder overheating? mosilvers Mercury & Mariner Outboards 3 October 20th, 2004 03:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
