PanamaRanger
- Sep 3, 2009
- 19
Can I remove and replace the exhaust cover without pulling the whole head? !991 70HP Johnson 3 cylinder. I think I have an exhaust gasket leak letting exhaust gas into the water area and causing overheating at higher throttle causing it to go to the SLOW mode.....lower RPMs it runs fine
I need a class for dummies I guess....Can I remove the exhaust gasket plate (plates?) and replace these gaskets without pulling the powerhead? I think I am smart enough to replace the gaskets but not smart enough to pull the powerhead...Can somebody give me a class for dummies on what to do??
I am OK with general type mechanical stuff (I used to rebuild air conditioning compressors) - but I am not good with outboards. I need to save as much money as I can right now. I am retired .....
(nuff said)....It looks expensive to take it to a shop and I need to try it myself unless I will do more damage than just letting it alone for now..
