  #1
Old October 18th, 2009, 11:25 PM
lvin4jc lvin4jc is offline
Default 1993 Yamaha 85 HP C85TLRR rough idling before quiting
On muffs, the engine will start but will idle very rough for a few minutes then die. Can re-start and keep running rough with throttle input. The remaining throttle positions will increase rpm but its not normal (very rough.
Actions taken:
Rebuild carbs but was not done by experienced mechanic.
Spark test – good spark on all three
Ran new gas/oil from surrogate tank
Compression readings #1 100 psi #2 90psi #3 95 psi
Replaced spark plugs with correct gap
After all of this, problem was the same.
Items that were not done yet:
Fuel pump replacement
Tear down the carbs again and give a good soak, spray, poke, making sure floats & seats are adjusted.
De-carb piston rings.
I am travleling down this week to see if I can help these folks and I’m requesting some of the pro’s to give me some thoughts on where to start. I am thinking either carbs again or puel pump.
Advice from experts??
  #2
Old October 21st, 2009, 12:33 AM
Default Re: 1993 Yamaha 85 HP C85TLRR rough idling before quiting
No feedback yet.....any pros out there that can give me a place to start. Going down to Melbourne tomorrow to try and figure this out. I'm convinced it is a fuel problem but wanted some feedback. If i can provide any additional information, please ask. Thank you
  #3
Old October 21st, 2009, 01:18 AM
sigma sigma is offline
Fuel filters, small pin hole in fuel line sucking air??????????????
__________________
Sigma
  #4
Old October 21st, 2009, 10:55 AM
99yam40 99yam40 is offline
Read this and others in frequent ask queastions
http://forums.iboats.com/showthread.php?t=283363
  #5
Old October 25th, 2009, 09:48 AM
Troubleshooting update
Here is what was done so far:
1. Very maticulous carb re-build.
2. Replaced fuel tubing from tank to carbs.
3. Checked fuel pressure from fuel pump....good.
4. Checked all linkage.
5. Compression test 100, 92, 95.
6. Bypassed fuel in tank using fresh gas & oil.
7. Swapped coils.
8. Spark test...all three good.
All of this had no change in rough idling and/or operation.
One wierd factor that may point directly to the problem is the fact that...while running (large throttle input needed to keep running), pull the bottom plug wire off (motor dies). pull the middle plug off (motor rpm drops but does not die), pull the top plug off (no...or very little effect at all).
Question - if i have good carbs, good compression, good fuel pressure and good spark.....is this a timing component failure...and if so, which part??
Thanks for your time!!
  #6
Old October 25th, 2009, 11:44 AM
Timing is easy to check on all 3 with a timing light, but it still sounds like a fuel problem if it is not affecting all 3 cylinders the same.
Spray some fuel mix into the different carbs while running and see if it causes the dead cylinders to fire.
If no difference then start testing the electronic components like the manual says
  #7
Old October 25th, 2009, 12:02 PM
david_r's Avatar
david_r david_r is offline
are there any signs of rodent activity?
you could have some blocked, cracked, or stuck reeds.
if you have a good blue spark that jumps the correct gap (sorry not sure how big a gap for a yamaha) then your problem is in the fuel delivery..... since your comp is good.
as said above spray some pre-mix into each carb... or at least the top 2 since the bottom cyl is obviously dragging the other 2. if you have noticeable difference and you are certain your carbs are clean i would look for an air leak around the intake...... your carbs get fuel from suction if you have an air leak the eng wont be able to suck fuel through the jets.
to test for an air leak i usually spray carb cleaner around the carb to intake and intake to block gaskets.... if its leaking air you will know it.
did you do the carb cleaning like in the faq section on this site?
__________________
give a man a fish and he will eat for a day...........teach him how to fish and he will sit in a boat and drink beer all day.
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercruiser 165 idling rough michael s. Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 17th, 2009 09:46 PM
Boat Idling Rough jennifer1762 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 June 11th, 2008 09:54 PM
87 Suzuki 150 SS, idling rough hankll Yamaha & Suzuki Outboards 4 July 10th, 2007 04:08 AM
idling rough Gudim Johnson & Evinrude Outboards 4 June 30th, 2006 10:06 PM
Still idling rough Scuda11 Johnson & Evinrude Outboards 8 June 29th, 2004 06:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
