I just bought a older boat with a 115hp evinrude when i got it the fuel pump needed rebuilt it would only start if you where priming it while cranking it over. I rebuilt the fuel pump and now it wont start. I got it to start with the fuel line unhooked but when i hooked it up after it started running it would die almost immediately. Any ideas what i could be the problem. I bought a new tank and fuel lines and primer bulb.
Thanks Brian
Thanks Brian
