  #1
Old October 18th, 2009, 07:51 AM
One4DelRey's Avatar
One4DelRey One4DelRey is offline
Default 1989 60 hp Mariner- lost forward and reverse
was out fishing this past friday and everything was working fine. motored to my spots, did a little troling and no problems. when returning to dock coming out a no wake zone as i accecerated it happened. bam- high rpms, i quickly shut it down. i thought i spun a prop. trimed it up, prop was still there, oh s#it! tried to start it back up, now no power double oh s#it! was towed back to ramp. trim didnt work, so needless say it was not fun towing it back home(now i have some skeg issues). this saturday i went out to check things out- low and behold, now i have power. started motor and still no forward or reverse. trimed it up, checked lu oil and it was a little milky with some very small metal debris on magnet. dropped the lu to check things out. there was a thick milky slime on the impeller housing. checked impeller- it was ok, not great fins bent, butt not broken. refilled lu oil then putt everthing back together. started it up and now no tell tale at all (in the past it took about 15 to 20 seconds to pee), and still no forward or reverse. took a break, then back to check some other things out- now no power once again....... anyone have any advice. i know i have lu issues, but whats this power issue- works, then not?
  #2
Old October 18th, 2009, 10:03 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Default Re: 1989 60 hp Mariner- lost forward and reverse
Quote:
this saturday i went out to check things out- low and behold, now i have power. started motor and still no forward or reverse. started it up and now no tell tale at all (in the past it took about 15 to 20 seconds to pee), and still no forward or reverse.
Ayuh,.... My Guess is,...
The splines are Gone in the bottom of the crankshaft, probably from a lack of Grease...
That explains both the lack of forward/ reverse,+ No water flow...
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #3
Old October 18th, 2009, 10:18 AM
One4DelRey's Avatar
bump......... one more thing to add. the prop would not spin with engine running either in forward or reverse. it used to spin a little in neutral before all the problems started. when i dropped the lower unit the splines on drive shaft were fine. then when i checked the lower unit i could turn the drive shaft by hand and the prop would spin. reassembled the lower uint then when prop was turned by hand it made a clunking noise in forward and reverse. but when powered up it would not spin. any ideas on what has happened,did i shear a pin on the prop?(does this have a pin) i can not get the prop off - have tried a prop puller and various other pullers and the d#mn thing wont come off.
  #4
Old October 18th, 2009, 10:22 AM
One4DelRey's Avatar
thanks bond-o, is this an easy diy fix?.. expensive?
  #5
Old October 18th, 2009, 11:14 AM
jackd1023 jackd1023 is offline
Give this a try it helped me. There is a "shift" shaft it is small and behind the main shaft. There is a collar on it that slips into the drive find the spline on the drive side and try to turn it. you should be able to find reverse and drive. My old pontoon boat had a 75 merc and for some reason the retaining clip would come loose and it would act the same. Heck worth a shot. Good luck
  #6
Old October 18th, 2009, 11:59 AM
Bond-o's Avatar
Master Shipwright
Ayuh,... As far as I know, If my guess is Right,... You need a New Crankshaft....
I imagine the cost would be gettin' close to motor replacement costs...
Btw,... Your Bump post pretty much confirms it....
__________________
  #7
Old October 18th, 2009, 02:17 PM
One4DelRey's Avatar
Bond-o........ I guess its time I look for a replacement lower unit. Should I go for a good condition used or rebuilt? thanks for your reply's
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lost forward and reverse boomman Johnson & Evinrude Outboards 12 June 16th, 2009 01:42 PM
73 Johnson 9.5 - Lost forward/reverse Sherriff Johnson & Evinrude Outboards 2 October 15th, 2008 12:29 PM
Lost my forward and reverse, HELP!!!!! longisldr Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 29th, 2005 07:06 PM
Lost forward / reverse simultaneously jsouthco Johnson & Evinrude Outboards 3 August 10th, 2003 02:26 PM
forward lost power ,reverse fine cjkerns Johnson & Evinrude Outboards 18 August 2nd, 2002 05:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
