StevNimrod
- Dec 13, 2008
- 343
I'm having a bit of a problem locating the correct bracket for the remote oil reservoir (for the lower unit). The LU is a Alpha 1 Gen 2 and the old engine was a 1994 5.7L (OF276159). On the old engine the reservoir bracket attached to the rear two bolts on the port side of the intake manifold. The new motor has Vortec heads so the bolt pattern is different (four bolts per side, but flat instead of angled like on pre-Vortecs).
I've been to the local Merc dealer a total of three times just to try to get the correct bracket. The last thing I was given was part #860065A1. The bolt pattern on this part does not allow its installation on the back of the heads.
Is there something I'm missing as far as where this thing goes, or does someone know the correct bracket I should be looking for?
