I just replaced the impeller and tested it by hooking a drill to the driveshaft and manualy turning the impeller while submersed in a tub of water. have good water coming out the top of the impeller housing. I also hooked a garden hose to the rubber hose that goes to the "pee hole" and I get water coming out the center of the prop but very little out the water supply tube when the lower unit is removed. my problem is I cant figure out how to get to the top end of the water supply tube where it goes into the bottom of the motor. I know there has to be something blocking the water flow there.
any help would be great!!!
