  #1
Old October 13th, 2009, 12:45 PM
Azonic Azonic is offline
Default Aluminum Starcraft , new wood floor, glass in or not?
I have seen several aluminum rebuilds and have learned alot about putting in the decks.
Sealing them and such.
I have also thought about glassing in the floor.
Is that a viable option?
How do you make the transfer from wood/glass to aluminum?
Thanks
  #2
Old October 13th, 2009, 02:24 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Default Re: Aluminum Starcraft , new wood floor, glass in or not?
You can apply fiberglass to the deck and as far as the transition..... you can cut it close to have a tight fit but people do not seal them up. The plywood is usually riveted/or screwed down to aluminum stringers.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #3
Old October 13th, 2009, 02:50 PM
Yeah, I am going to go back with rivets, as that is what is there now.
And I like the idea of a glassed deck (i think) but did not know if you seal her clean to the hull or just up to the edge and stop.
I am not sure why you would glass it at all if you did not seal her clean to the hull.
You will get the water running down the edge of the deck and hull and introduce water anyway. Is it not better to seal the deck like a cap and use a good bilge pump and vent?
So what am I missing in the concept?
  #4
Old October 13th, 2009, 02:55 PM
Knightgang Knightgang is offline
Glass the deck mearly to protect the wood from premature water damage... Glass both sides and seal the wood...
  #5
Old October 13th, 2009, 03:19 PM
ezmobee's Avatar
ezmobee ezmobee is offline
Send a message via MSN to ezmobee
I think the recommended process is to epoxy resin the bottom, resin and glass the tops. But Azonic brings up a good point, what do you do to protect the edges beyond just a simple coating of epoxy?
__________________
1976 18' Starcraft SuperSport 90HP Evinrude
Restoration thread http://forums.iboats.com/showthread.php?t=357767
1966 16' Starcraft Jupiter 85HP Johnson
Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
  #6
Old October 13th, 2009, 03:22 PM
I have seen where resin or sealer is applied to the bottom and side (and all joints) then installed. Either sealed again top side or glassed to the edge...
I know carpet is a no no...
I hope to get some room in my shop this weekend, and pull my boat in and start the work...
tear down, planning is 50% done (theory portion) then I need to do real world size cardboard templates of everything. Then the floors come up, hull cleaned, sealed, repainted, then floor.
I just want to wrap my head around this whole glass no glass flooring.
  #7
Old October 14th, 2009, 12:54 PM
Quote:
Originally Posted by ezmobee View Post
....But Azonic brings up a good point, what do you do to protect the edges beyond just a simple coating of epoxy?
I look at it as the work of glassing the top is way overkill if you just have resin on the sides and bottom, and allow water flow to those locations.
  #8
Old October 14th, 2009, 01:03 PM
ezmobee's Avatar
I agree. I guess you'd pretty much have to glass the edges prior to installing the deck pieces in the boat. The one thing that glassing the top after installing the deck into the boat does indeed do is completely seal all of your fastener holes. I'm really starting to think I'm not going to glass anything. Just coat with epoxy resin as best I can and then Durabak (or similar) it. I keep my boat covered or in my garage a large majority of the time and I'm thinking even unprotected deck wood would last a pretty good while for me.
__________________
  #9
Old October 14th, 2009, 03:07 PM
I want to protect mine in someway...
However I agree. treated lumber would last a long time, even un protected.
Aleast my deck has!
I was originally thinking about a good outdoor paint for the bottom and sides.
then a good epoxy or resin to fill the deck fastners and any accesories mounted to the floor, and add a nice fresh coat of outdoor/concrete paint to the deck...
Toss in some play sand for traction and call it a new deck?
With that said...
my cabin cruiser has a full on fiberglass floor with a nice little traction pattern in it... however, duplicating that would require glassing the whole deck and up the sides of the aluminum skin...
Still a mystery of what to do ....
  #10
Old October 14th, 2009, 03:20 PM
ezmobee's Avatar
Don't use treated lumber anywhere near aluminum.
Concrete paint will be too brittle for this application. However, a good porch and floor paint should work.
__________________
  #11
Old October 14th, 2009, 03:59 PM
so you were thinking the new composite decking?
I can see the brittle thing too..
I have some very good outdoor "grey" paint that is for wood.
Can't see why that would not work...??
the one major issue I have is the things fastened to the deck..
Center console, seats, cooler mounts, etc....
Seal those hose where screws go through, protect the underside of the material used to make those items, and prevent a path of water striaght to the hard work I just did!??!
  #12
Old October 14th, 2009, 04:20 PM
coolbikeguy coolbikeguy is offline
Send a message via AIM to coolbikeguy Send a message via MSN to coolbikeguy
seal all 6 surfaces .. top,bottom and 4 edges. then wrap the edges with glass and the top with glass .... done thats how im going to do it. the glass on the top is just to add a little extra strength. the epoxy sealed bottom will not soak up water.
__________________
my SS resto threadhttp://forums.iboats.com/showthread.php?t=355025 ...
  #13
Old October 14th, 2009, 07:39 PM
North Beach's Avatar
North Beach North Beach is offline
Send a message via MSN to North Beach
Guys the fiberglas adds not only waterproofing, but strength. If you don't want to be re-flooring that boat in a short time, spend the little extra and do one ply of glass re-inforced epoxy resin on the top. This will also protect the wood from misc damage from equipment droppage, sharp edges, etc.
Not tryin to flame anyone here, but folks are always tryin to re-invent the wheel on this subject. For the money, the best approach would be 1/2" marine grade douglas fir (5 ply) made with the highest grade waterproof glue. Epoxy resin bottom and sides with at least one coat, two or three if you can, and one ply of glass mat and epoxy resin with another coat of epoxy resin over that. Then you can paint, vinyl, whatever. With this approach you have strength, not too much weight, and you won't be taking it all up in a couple of years.
I just picked the LL up at the boat mechanic's today. 5 mins into the trip home and downpour. Everything in the boat was totally saturated by the time i got it home and I'm not worried about my deck one bit.
Also the aluminum will flex too much to try and glass up and onto the sides. End your mat at the edge and it's done.
JMHO
  #14
Old October 14th, 2009, 08:46 PM
Greendiver's Avatar
Greendiver Greendiver is offline
I am exactly in the same boat! (thank you, thank you! get it? boat!?)
I wrestled with this one for a bit and then followed what NB suggests above, as well as others.
My deck is now riveted down. I used 3/4" and sealed the bottoms and sides really well with epoxy resin and intend to layer the top with mat and more resin. I have no concerns now about the durability of this deck.
__________________
1972 21' Starcraft Mariner - Mercury 115
http://forums.iboats.com/showthread.php?t=349630
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing floor on Aluminum boat, suggestions on wood... KewlBird Boat Restoration and Building 27 December 4th, 2008 10:46 AM
Deck Plates to fix floor rot in my 16' aluminum starcraft febod Boat Topics and Questions (not engine topics) 1 August 30th, 2006 05:07 PM
Wood top for glass boat? oceanaddict Boat Restoration and Building 7 December 6th, 2004 04:08 AM
Poly -N- Wood -N- Glass Trick? pjc Boat Restoration and Building 4 October 9th, 2003 04:51 AM
all glass stringers? no wood? does this mean ??! jvolpe28 Boat Topics and Questions (not engine topics) 1 May 13th, 2002 07:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
