  #1
Old October 13th, 2009, 09:28 AM
shawnswan shawnswan is offline
Default Prop Size? 30HP Johnson on 20' Pontoon
I lost my prop this weekend, luckly I was just pulling into the marina. I need a recommendation on what size of prop to get. I've got an '85 30HP Johnson on a 20' Pontoon boat.
Thanks.
  #2
Old October 13th, 2009, 03:35 PM
steelespike steelespike is offline
Default Re: Prop Size? 30HP Johnson on 20' Pontoon
It is difficult to know what prop would be best without some sort of base line performance.My guess is about a 7" pitch.It may be a little light but its better to be light cause you can still use it and just throttle back so you don't over rev.A four blade pontoon specific prop will perform better than most 3 blade props.
  #3
Old October 15th, 2009, 09:07 AM
The guy at the local marina recommended a 11" pitch 10" dia. 3 blade. Does this sound right?
  #4
Old October 15th, 2009, 11:45 AM
I'm not an expert but::
Doesn't sound right to me based on what I've compared it to.
The present day Evinrude 30 on a 900lb 16ft pontoon runs a 9" pitch
at 5,900 rpm and 17 mph. Same motor on a standard 600lb 16ft Starcraft
outboard runs a 12" pitch at 5,800 rpm 27 mph.
Your 20ft pontoon has to be 1200 or 1400 lbs dry.These motors are similar
though gear ratios may be slightly different Your motors hp is rated at 5,500, like the Evinrude, your rpm needs to be between 5,500 and 6,000.
There is no way a 11" prop will do that.If he will let you try props to get the right one you could start at a 9" and go from there to get the right rpm.
If you run with the family most you need to shoot for the higher rpm so
the motor will stay within its rpm band when loaded.
Again my thoughts on a 7" were you could run it even if a little light where a 9" if to much you shouldn't run it at all because it will make the motor lug.
Could cause premature engine failure.A 4 blade pontoon prop will deliver the best performance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop size for 40hp rude on 18' pontoon?? tawd77 Prop Questions and Topics 10 April 27th, 2009 02:01 AM
Prop size for pontoon/house boat beavertrapper70 Prop Questions and Topics 3 August 13th, 2008 03:04 PM
What size prop for a pontoon? heavyduty413 Prop Questions and Topics 3 August 10th, 2008 09:32 PM
pontoon boat prop size luvthelake Prop Questions and Topics 1 July 7th, 2008 11:20 AM
prop size for pontoon KennyA Prop Questions and Topics 1 June 18th, 2006 04:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
