n26panache
- Sep 2, 2009
- 7
Hi all - I discovered this site while searching for an answer to my recent, sudden problems with my outboard. I haven't been able to find a post that quite describes what's happening to my old merc.
The outboard is on the back of my 26' sailboat. I went out the other night in pretty fun conditions: big wind and big waves. The motor was fine on the way out. When it came time to motor back into harbor, I couldn't get any power in gear. Luckily the wind was blowing me "in", so we made it safely back to the slip. (the motor usually can push the boat about 5.5 knots - I can't even get it up to 2 now)
It seems fine in neutral. Even in gear at idle is acts as it always has. When I try to throttle up, it doesn't rev up; instead, it just shakes more and sounds pretty terrible.
My initial thought was that maybe while we were sailing in the waves, the motor got banged around and a plug wire came loose. Checked the plug wires, and no problem.
With all the vibrating and shaking I thought: "Maybe only one cylinder is firing, even though it seems ok in neutral...". I changed the plugs. The motors starts easier with clean plugs, but otherwise, no change.
A sailing friend said it sounded like I had weed wrapped around the prop. There's nothing visible, but there's certainly lots floating around that maybe have gotten twisted around it at some point. Is it possible that it's wound so tight I can't see it?
It's difficult to work on the motor as it's hanging over the water - it's a huge deal to haul the boat out. Anyway, I might be able to borrow a dinghy to get a closer look at it.
Any ideas what I should look for?
