shankforce
- Sep 9, 2008
- 114
The install seems preaty straight forward on the Poppet.
First let me start off in saying when I took the cover off I had a lot of salt water corrosion on the inside of the cover that touches the gasket.
Second from what I have read this was supposed to pop out since it is spring loaded. It did not. It is stuck so as you know if you investigate any further you are replacing the whole set up in which I ordered one.
I am thinking this is either stuck shut or stuck open that is why It will not pop out. After prying a little on the inside diaphram I tore a little hole in it.
So my symtoms before I investigated the popett valve were blowing steam out of my teltale hose. The thermostatts are new and not defective and my water pumps seems to pump strong (bought another just in case I could always replace it anyway). starts steaming in idle gear when I come in the dock area causing it to start to overheat.
