  #1
Old October 13th, 2009, 05:22 AM
EasyRider156 EasyRider156 is offline
Question 60hp mariner head torq specs
I have a 2 cylinder 60hp mariner,and was wondering if anyone knows what I Need to torq the bolts to. Im not sure of the year of the Engine, the plate has 675 L 34???, cant remember the last three numbers. All i can say is that its a 2 cyliner, and that it has 8mm stainless steel bolts, they have an 8 on the head so Im guessing their 8.8 grade, and that its an alloy block and head. Any help would be great.
thankyou
  #2
Old October 13th, 2009, 05:27 AM
Default Re: 60hp mariner head torq specs
I think it was made some time in the 80's
  #3
Old October 16th, 2009, 04:20 AM
I have now put my head back on my outboard with great results, found out of three different machanics, just to make sure, the head bolts need to be torqued to 18ft lbs. Thought i would post this just incase someone needs this info, I had the head machined and would advise anyone to do the same thing to get optimum results,all up this cost me under $100 to get the gasket and machine the head, it was an easy job to do, and would have cost me hundreds to have a machanic to do.
Just dont forget to use anti seize on the bolts, nothing worse than a broken one.
  #4
Old October 16th, 2009, 04:33 AM
Tightening pattern used: starting from two middle bolts work in a circular motion,
8 7
4 3
1 2
5 6
9 10
DONT tighten to 18 ft lbs straight up, tighten by hand up evenly, using the pattern, then using torq bar take them up to 10ft lbs then up to 18, then check the pattern again at 18 to ensure they are all even.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Head Bolt Torq. 115johnson78 Johnson & Evinrude Outboards 2 August 16th, 2009 12:11 PM
head gasket cover torq settings?????? bluebrownie Force & Chrysler Outboards 9 August 12th, 2009 03:34 PM
91 mariner magnum2 150 head torque specs? astromariner150 Mercury & Mariner Outboards 0 May 20th, 2009 10:03 PM
Need Head Torque specs for older 8HP Mariner pmcs Mercury & Mariner Outboards 3 September 7th, 2008 10:27 PM
Merc Torq Specs. Help Please Walker Mercury & Mariner Outboards 2 June 21st, 2003 03:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
