  #1
Old October 12th, 2009, 06:12 PM
bd28 bd28 is offline
Default 89 evinrude 30hp starter drive gear
i have an 1989 30hp evenrude when i turn the key the starter spins but the drive gear that will turn the motor doesn't engage wondering if drive gear was bad and if anybody knows how to get it off
  #2
Old October 12th, 2009, 06:58 PM
bktheking's Avatar
bktheking bktheking is offline
Ensign
Default Re: 89 evinrude 30hp starter drive gear
Is the battery in the boat good, connections going to the starter good, have you bench tested the starter off the boat. The drive gear probably isn't bad, sounds like a power issue.
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #3
Old October 13th, 2009, 06:03 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
couple of drops of oil, on the bendix, then turn the gear up by hand. also 90% of the time it is not the starter.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old October 13th, 2009, 10:20 PM
i put some penatrating oil on gear and let it sit overnight then tried to start had no problems gear went up and down with no hesitation then a added some 3in1 oil on shaft and gear seems to be working alright is that a normal problem how often should i oil the shaft
  #5
Old October 14th, 2009, 04:57 AM
just a slight bit of oil, every time you winterize. it probably has not been done in 20 years.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'56 Evinrude 30hp coming out of gear greatoutdoors Johnson & Evinrude Outboards 44 September 6th, 2009 05:48 PM
88 28hp spl starter drive gear replace Tim heath Johnson & Evinrude Outboards 2 July 8th, 2009 08:50 PM
1972 100hp starter or drive gear bolodunn Johnson & Evinrude Outboards 1 March 13th, 2009 07:39 AM
Starter drive gear trouble on 1983 Johnson 90Hp owens Johnson & Evinrude Outboards 3 June 28th, 2007 07:43 AM
30hp Evinrude Starter Rope WetDawg Johnson & Evinrude Outboards 5 December 7th, 2006 02:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
