Re: slow boat
I think you'd have better luck posting this in the engines and drives section. It's not a Reagl specific problem. That said, I don't think the temperature fluctuations seen have anything to do with the power problem, unless the thing was overheating while power was an issue.
The power issue could be caused by many things. First thing I'd suspect is fuel delivery since it sat for 5-6 weeks, you mentioned "old gas" and there's an awful lot of gas with ethanol out there. Check your fuel filter for signs of water.
