Re: Netbooks
I think the question is... what are you going to use it for. Are you just looking at the ones offered through your phone company because they advertised it to you? Or are you really going to need the 3G connectivity?
If you just want to be able to connect at home or local "hotspots" then I would suggest that you look at buying one from a retail store or online. I have seen the netbooks go for as little as $199, but more often $250- $300. If you REALLY need the lightweight portability, then a netbook may be your best option. If you can get by with something slightly larger, then a regular laptop may be a better option. I have only ran across a small number of folks who really NEED to have the 3G connectivity, and that was usually due to their job functions.
I have a friend who has a netbook and loves it because they take it to church and can follow along with the bible readings (they have the bible loaded on the netbook). But they also have a regular laptop or computer for most other things. One other thing to remember is that the netbooks typically do not have anytype of external drive (CD, DVD, etc) so you have to purchase a seperate drive or download everything via wi-fi.
HTH
