I Rebuilt The Carb, New Lines, Plugs, Gas. Runs Great. My Problem Is That I Can't Move The Throttle Past The Start Setting When In Neutral. So Its Hard To Rev It Up When You 1st Start As It Can Only Run In Slow Or Idel.
I Have Adjusted The Setting On The Outside Of The Tiller As Far As I Can. I Can Put It In The Start Position, But Can't Increase The Speed In Neutral, Throttle Linkagge Hit The Pin On The Gear Setting.
I've Taken The Tiller Gear Shaft Out And Tried Different Positions But Still Can't Get It.
Aren't You Supposed To Be Able To Have Full Range In Neutral?
Suggestions?
Thanks
Kc09
Suggestions?
Thanks
Kc09
