90 Force - No reverse and ect.
Neonguy95
90 Force Motor.
I am working on the boat for my wifes uncle so I am unclear on how long problem has been around I am assuming the start of the summer as he has not used the boat this year.
Problem - Motor will start in forward gear and has no reverse.
I can see the lever move when the hand control is moved so I know the cables are moving as intended.
My thoughts - After searching some my first guess is cable adjustment. Wanted to check here before attempting anything. I mechanic by trade, however I am diesel refrigeration tech.
Thanks for any help.
Rusty
foodfisher
Re: 90 Force - No reverse and ect.
I would start there there also. Disconnect the cable, put throttle in neutral, manually put motor in neutral,adjust and reconnect cable. Good Luck
