Re: 50 hp mercury 4cyl outboard new impeller no water flow
Hi,
Are you sure you got the water tube in the rubber grommets.
Is the tell tale hose plugged with something?
There is a brass plug in the back water jacket that you could take out and run the engine for a little bit to see if it is filling the block.
__________________
This is free internet advice.
Have Fun,
corm
