  #1
Old October 6th, 2009, 02:53 PM
Ballen14 Ballen14 is offline
Default Evinrude 70 hp power loss
I have what appears to be a late 70's Evinrude 70 hp outboard. It will run great on the muffs or in a barrel without a load, but with a load i can open the throttle all the way and it takes longer than usual to get on plane, sometimes with a sputter and then it sounds like it catches up. It may plane eventually depending upon the weight in the boat. With only a few people and some tackle it picks up quickly sometimes, but sometimes it still drags or hesitates. I have taken the carbs apart and cleaned them and checked for sticking valves and it ran great right after that but then went back to its loss of power. Compression checked at 100 psi on all 3 cyl. Once on plane it runs great, but it seems to be lagging to get there. I do smell excess fuel and it leaves a little in the water when sitting still. I also see quite a bit of excess in the breather box when i take it apart. I have done a few backyard tests to try and figure out if it is a carb or powerhead issue and from what i have been told it sounds like carbs. Any ideas from anyone with more experience would be greatly appreciated. I am tired of taking the carbs on and off and not getting results i need. I have rebuilt them already and was thinking about replacing them, but if it is a powerhead issue there is no reason. Thanks!
  #2
Old October 6th, 2009, 02:59 PM
bktheking's Avatar
bktheking bktheking is offline
Ensign
Default Re: Evinrude 70 hp power loss
Did you replace the internals of the carb with carb kits? Were they soaked in heavy duty carb cleaner over night?
__________________
1983 Thundercraft 16.5 * 1983 Johnson 90 v4 * 1983 Johnson 9.9 * 1965 Evinrude 9.5 * 1955 Evinrude 7.5 * 1951 Viking 3 **Latest-76 Evinrude 15
  #3
Old October 6th, 2009, 03:06 PM
Daviet Daviet is offline
Master Chief Petty Officer
A couple of thoughts, have you done a compression and spark test? Spark should jump 7/16" and be bright blue.
You didn't list your model number, but I am assuming you have 3 carbs. You can remove the 7/16 plug in the bottom of the carb bowel and that will give you access to the high speed jets. Remove and check the jets for restrictions, it don't take much to block them off. You did remove and clean all jets and blow out all passages when you rebuilt your carbs didn't you?
You should probably replace the fuel lines if not done already, they tend to flake inside and plug jets.
If that does not help, use an inductive timing light to check spark when engine is preforming poorly, have someone run the boat for you. If you are dropping a cylinder it should show you which one. What do the spark plugs look like?
  #4
Old October 6th, 2009, 03:39 PM
dkski dkski is offline
Ever hear of Occam's Razor? Usually the simplest solution is right? Not always, but I had a similar issue with a 75hp 1976 Johnson. I replaced the powerpack, rectifier and coils (also had the marina rebuild my carbs). Still had the same problem! Believe it or not it was BAD gas. After running about two cans of seafoam through the fresh gas and oil it came alive. Be certain you have checked all the simple solutions first. Do you by any chance have any air getting in the fuel line? For about $10.00 you can re-due your gas line and eliminate that as well.
Good luck!
  #5
Old October 6th, 2009, 08:56 PM
Thanks to all for your help! I have done a spark test and am getting good spark on all plugs,which are a little wet, i did use kits to replace the internals and adjusted to the correct float specs, i also pulled the 7/16 plug and thoroughly cleaned the jets. I also have replaced all the fuel lines. The motor is used almost every weekend and gas is pretty much new and doesn't get over two weeks old most of the time. It ran well after i rebuilt the carbs, but only for a few months. Since the problem has started i have taken the carbs back apart and cleaned and made sure floats were adjusted correctly and valves were opening and closing properly. I have noticed a small amount of fuel spitting out of the top carb when i run it with the covers off in the yard. But the vavle doesn't seem to be sticking when i take it apart and check it.
Thanks again for the replies!
  #6
Old October 6th, 2009, 09:06 PM
bktheking's Avatar
Ensign
What about compression test readings?
__________________
  #7
Old October 6th, 2009, 09:47 PM
I checked 100 psi on each cyl. Not sure if that is low or not because i have seen some other models getting 120-140.
  #8
Old October 6th, 2009, 10:35 PM
bktheking's Avatar
Ensign
100 should be fine, a little worn but nothing to cause concern, I think if they are close across the board you are in good shape. At this point if you are confident the carbs are clean and in good shape i'd start looking deeper, gas spitting out the carbs is a sign of carb issues (which you are confident you ruled out) the the reed valves could be damaged, pull the intake and check them out.
__________________
  #9
Old October 6th, 2009, 11:48 PM
Thanks bk. I have def not ruled out the carbs, i have just taken them apart and cleaned and checked them so much i feel like a pro at it! I def wanted to make sure it sounded like a carb issue before i spent any more money on the carbs themselves. I was contemplating just trying to replace all three and trying that. However buying these older parts for an ok price may mean trading one problem for another. I will keep workin with the carbs though and hopefully i can find the one that is causing the problem and get rid of it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loss of power 35 HP Evinrude Deanrt Johnson & Evinrude Outboards 13 November 2nd, 2007 08:14 AM
1979 Evinrude 70 surge in power/loss of power huntingjustinlouise Johnson & Evinrude Outboards 6 April 8th, 2006 05:36 PM
Evinrude 90 hp loss of power, help please.... rsbbdut Johnson & Evinrude Outboards 1 August 4th, 2005 06:21 PM
EVINRUDE 6HP POWER LOSS BASSMASTERJ Johnson & Evinrude Outboards 4 August 6th, 2003 11:19 AM
6HP Evinrude loss of power work4bait Johnson & Evinrude Outboards 1 August 27th, 2002 10:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
