toolsengineer
- Aug 28, 2009
- 3
I have a pair of 1995 Johnson 150s with the composite Carburetors. Noticed 1 started burning more gas than the other ( 10 %). Looked in the carbs and 1 showed gas buildup when pumping the bulb. Installed a kit and the problem remained. After careful inspection noticed hairline crack in the upper carb body leading up from the fuel inlet hole. Changed out and cured the problem. Couple months later developed a sneeze / miss. Isolated to #2 cylinder. Same thing cracked carb in almost the same place leaning out at idle. Found a used one at a dealer and noticed it was also cracked in a similar manner. Has anyone else noticed this issue?
