NovaScotiaBoata
- Aug 28, 2009
- 3
I recently picked up a 17.5 ft fiberglass grew with a Mercury 50 hp 4 cyl. 4 stroke (like new) and have found a couple snags. The boat has sat and been worked on more times than it has been in water. Seriously, the boat has sat in the same spot for about6 years. The engine has about 15 hrs on it after a new rebuild.
Here are the issues:
Engine idels perfectly but after put in gear it sputters until a little after half throttle. Full throttle it runs great but when decreasing throttle the engine quits. That is problem 1.
Problem two (may be related) after running the boat hot for a while and shutting it down it, immediately after trying to start it again it blows the main 20 amp fuse (as manual suggested).
After the engine cools down it starts and runs fine. (besides problem 1 listed above)
Made some brief adjustments to the throttle tension it worked like a top....until first decelleration..the problem 1 continued.
The boat has lots of oil and has been very well maintained.
Any suggestions would be greatly appreciated,
:redface:
Thanks.
:redface:
Thanks.
