hi folks hope you can help me as i am nearly bald headed over this problem. the engine is a 2003 60 degree looper,model #j115pxsts. first start of the day squeeze the bulb,turn the key,push the key in and it starts immediately idles thru a half mile of no-wake zone better than great! jumps up on plane smooth strong power 40 mph for five or six miles just a singing it would make you proud never a hiccup,burp,spit or miss. now here is the problem. if i shut it down to fish for 2-3 hours, i repeat my initial starting procedure and let it idle for a few minutes and put it in gear advance throttle lever it will stutter and die. take it out of gear and bump the key it fires right back up put it in gear and advance the throttle it stutters and dies, this scenario continues thru 5 or six attemps with me feathering the throttle until it finally catches and i am able to take off. it is maddening i have a recent carb job,new fuel/water separator,new wires ,new plugs,new squeeze bulb, carbs were linked and synced,fresh fuel and two johnson certified mechanic that are mystified i promise a case of your favorite beverage to the wizard. thanks for your help Snukes.
