1986 Force 85hp
model 856f7b
Took the boat out today and kept blowing the breaker at the bottom of the electric cable terminal (8 wire?). As long as the motor isn't running the tach, tilt etc work fine. When the motor starts, however, the breaker trips almost instantly. Haven't played with anything at all that would explain this. Do these breakers go bad, or is there something else I should check? Hoping to save the weekend...
model 856f7b
