  #1
Old October 5th, 2009, 08:09 PM
Jay23 Jay23 is offline
Exclamation Evinrude 200 - primer bulb flat / alarm sounding
1989 Evinrude 200
I took my boat out yesterday to try the motor on the water for the first time.
The motor cranked up and idled just fine fine as i was backing off the trailer, but within about 3 minutes the trouble alarm started going off steadily. My temp gauge read 135-140, the tell tale was pissing water, and while the motor was running I shot the top of the heads with a infrared temp gun and they read 135-140 as well. I know its not the VRO because I have the pump and plug disconnected.
After about 45 mins of panicking that yet again another motor was overheating its way into self destruction, I noticed the primer bulb was flat. I tried pumping it a little and I noticed every time I slighty squeezed it, the alarm would go off.
Im guessing that the fuel restriction alarm was going off. Im going to change the water separator and in line filter and see if that helps, the bulb is less than a year old. Is there anything else I should be looking at? Am I right about the alarm being fuel related?
  #2
Old October 5th, 2009, 08:14 PM
noelm noelm is offline
Default Re: Evinrude 200 - primer bulb flat / alarm sounding
flat primer is pretty simple, it is a blockage/restriction between the primer and the tank, common cause, vent blocked, filter blocked, fuel hose kinked or soft, or picked inside tank blocked, easy method to test vent, is just unscrew the filler cap, it has NOTHING to do with the VRO!!!
  #3
Old October 5th, 2009, 08:16 PM
just re read your post, what do you mean about the VRO "pump and plug disconnected"?
  #4
Old October 5th, 2009, 08:18 PM
I unscrewed the fill cap and that didnt seem to help, I may not have left it long enough though. After about 5 minutes, I didnt notice a change and the alarm didnt go off so I screwed it back on.
  #5
Old October 5th, 2009, 08:21 PM
Quote:
I unplugged the 3 wire plug the runs off the oil pump and put a stop in the hose where the hose from the oil tank would connect.
  #6
Old October 7th, 2009, 10:08 PM
I removed all the fuel filters to replace them today and thought maybe I have too many. Could this be causing the primer bulb to go flat, or is the motor working to hard to pull fuel through 3 filters?
Heres my setup:
Gas tank----->Racor Filter-----> Inline Glass Filter----->Primer Bulb---->Inline Filter under motor cover (OEM)---->Motor
Im going to change everything from the Racor foward to see if that makes a difference but from what Ive read, the anti siphon valve seems to be the most common culprit.
  #7
Old October 7th, 2009, 11:47 PM
the primer valve can be a problem, but not all that common, can you run a line direct from the tank to the primer? or just buy a new primer and replace it, fairly cheap and easy to do.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
primer bulb went flat junior1113 Johnson & Evinrude Outboards 8 July 22nd, 2009 01:55 AM
primer bulb sucking flat luv2hunt Johnson & Evinrude Outboards 17 May 21st, 2005 10:20 PM
flat primer bulb billyt Johnson & Evinrude Outboards 1 December 31st, 2004 09:14 PM
primer bulb keeps going flat phatmanmike Mercury & Mariner Outboards 7 August 9th, 2004 10:44 AM
Primer bulb flat Bolo Yamaha & Suzuki Outboards 5 August 21st, 2002 04:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
