  #1
Old October 5th, 2009, 06:30 PM
Billfo's Avatar
Billfo Billfo is offline
Send a message via MSN to Billfo
Default Tilt & Trim
Looking for experienced opinion to fix.. I have a 2000 Optimax 135 with a Stingray hydofoil tail.. Runs great with the exception of the tilt/trim indicator.. I think something is out of adjustment (if that is possible) not sure if this is a do it your self fix.. Heres my problem..
Looking at my tilt & trim gage, while running, all my movements is only reflected on the FIRST 1/4 of the gauge. my hole shot starts at the gauge all the way to the left... Up on plane as much as I can trip up, is at the first quarter mark. Anything higher, I loose the bite. So basically 3/4 of the gauge does not do anything for the boats performance.. Anything higher than 25% on the gauge is just lifted the prop out of the water.. Is this an adjustment ? Thanks for any suggestions.
My last two boats were closer at midrange ( 50% in the middle of the gauge) when up on plane at wot.
  #2
Old October 9th, 2009, 01:49 AM
ziemann's Avatar
ziemann ziemann is offline
Default Re: Tilt & Trim
Billfo- see if anyone on the Merc forum here on Iboats knows- I am not sure on a Merc- it is adjustable on an OMC/ BRP outboard, so I would imagine it can easily be done on your Merc as well...but that is speculation on my part...
Good luck! :-)
  #3
Old October 9th, 2009, 05:39 PM
greenbush future greenbush future is offline
I run a Lund Tyee with a 115 Merc 2 stroke and my trim dash gage is just like yours, I bet 25% is all of the gage I see/use. The top 3/4 never is used when under driving conditions. I never bothered to check if the gage actually goes all the way up when I am trailering or fully in the up position.
I dont think your gage is broke, I think this is how they run, when on plane and trimmed out I am only using a very small portion of the bottom of the gage.
I think each boat or gage has it own levels of how to read the gage, I dont think your trim gage is broken.
  #4
Old October 10th, 2009, 03:34 PM
Billfo's Avatar
Thanks for the reply, yeah it s probably not broken, jus the way it was installed.. As said above, there is probably an adjustment.. I will see what I can do in this off season... thanks,.
  #5
Old October 10th, 2009, 03:36 PM
Billfo's Avatar
Thanks, I will be hopeful for an adjustment. It will be easier to have the gauge read level when up on plane, expecially when having others drive the boat !
Quote:
Good luck! :-)
  #6
Old October 10th, 2009, 11:13 PM
Navy Jr.'s Avatar
Navy Jr. Navy Jr. is offline
Our '08 1750 Fisherman is the same. I've learned to think of it as the first 25% is for trim, the remaining 75% is for tilt.
Also, at almost the 3/4 mark is about the furthest I can tilt it before the water intakes near the skeg are no longer submerged. Definitely want to keep it under 3/4 if the motor is running. We have (well, had; there's been a fair amount of rain lately) some shallow ramps where you need to worry about the LU hitting bottom.
Anyway, I doubt seriously if there is an adjustment to make it level when at optimal plane. Perhaps instead you could tape a mark on the outside of the gauge for other drivers. - Ken
  #7
Old October 11th, 2009, 01:06 AM
Billfo's Avatar
Interesting replies. Apparently, it is suppose to be like this... I know my 2 prior Evinrudes were not like this.. Maybe something I just need to re-educate my self to grasp... Again, not earth shattering.. I should just be happy the boat & motor runs great. Seems like Optimax has some issues. For me too soon to tell, but for now I am pleased with our purchase & this forum.. Thanks for all the replies.. !!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Force power tilt/trim tilt cylinder leaking basj8yw Force & Chrysler Outboards 5 October 27th, 2009 09:50 AM
90hp Trim Tilt on a 70hp Trim Tilt reeldeep22 Yamaha & Suzuki Outboards 0 June 19th, 2009 11:15 AM
installing power tilt/trim on non tilt/trim motor rallysman Mercury & Mariner Outboards 3 August 21st, 2008 10:32 AM
Tilt and trim problems (tilt lowers, trim does not) Leinenkugel#1 Force & Chrysler Outboards 5 July 16th, 2008 09:32 PM
pt130 tilt trim question without tilt assist hooked up holmzee1969 Non-Repair Outboard Discussions 2 June 26th, 2007 03:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
