Salem johnson
- Aug 28, 2009
- 4
I have a Johnson 115 (1978) new to me. It was installed by the marina where I purchased 2008. It throttles fine in low and hi range but when it gets to a certain point, about 5/8s to 3/4 of the way forward, the engine stalls. Sometimes if I manually choke before it gets to that point, it will continue to operate. The fuel pump has been rebuilt, the gas line from the fuel pump to the tee fitting going to the carbs has been changed, the marina changed a power pack, the carbs have been cleaned, a separate in line fuel filter has been installed, and it still continues to stall. Sporatically the bulb will not become firm when squeezing to fill the line with fuel.
