leadpencil2
- Jul 9, 2009
- 34
Hello all, I fairly new to boating world (from an adult perspective) and have recently taken ownership of boat and motor, everything works great with no major issues to speak of. With that said I need to know if the following is cause for alarm. Upon receiving my new toy (1965 Alumacraft Maracaibo / 1966 Johnson 60hp VXL-12R) I changed the lower unit oil and gently testing everything. While emptying the lower unit oil I noticed that the first few ounces of liquid that came out was water followed by oil. Since it was not milky and I was only going out for a short ride to test everything I wasn?t to concerned. I figured I would I would go though the lower unit over the winter anyway.
As a last weekend for boating (at least for me) I figured that I would take my new toy out for Labor Day. While doing a once-over last night I noticed a leak from the lower unit (see photos). I am guessing that this is where the water is penetrating the lower unit, but am concerned about the location. It appears that the leak is coming from a bolt above the lower unit filler inlet. I would assume this is because the motor is at an angle due to the tailoring brace. Is this cause for alarm before one more weekend of boating before winterizing and lower unit rebuilding? I would change the lower unit oil again prior going out just to be safe.
Thanks in advance,
Matt
Thanks in advance,
Matt
