propeller sugestion for 2003 Bayliner 195 with 3.0
KPECOD
I recently bought a 2003 Bayliner 195 classic (bowrider) for taking the kids tubing on a local lake. Unfortunately, it seems that I have been using my prop as a depth finder to find out where I CANNOT go in this lake. My question is: I need a new prop, but I have no idea whewre to start in terms of pitch or material. Specs on the boat are WOT 4800 rpm's at around 43-45 mph. I am trying not to loose too much top end speed, but I would like a good whole shot to get the skis and tubes up quickly.
Thanks in advance for any help.
Re: propeller sugestion for 2003 Bayliner 195 with 3.0
Ayuh,... Welcome Aboard,...
Unfortunately, You're in the Wrong forum, this is the I/O forum, you need the Prop forum...
Hang tight, I'm sure a Moderator will move it for you....
Btw,.... We'll need to know What the motor is, What the drive is,+ What the current prop is....
As well as what it was running, Before you went dredging....As in WOT rpms, etc...
hwsiii
KP, welcome to Iboats prop forum and we will try to help you as much as we can but without more information no one can help you, and I will tell you I need more information than anyone else. But if you would like my help fill this form out and I will help you as much as I can, if you would prefer to not go to this much trouble there are other people who will gladly help you.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the maximum recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make. manufacturer and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape a c ross the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
KPECOD
Bond-o,
It is a 2003 Bayliner 195 classic with a Mercruiser 3.0 which was running at 4800 rpm's WOT at about 45 mph. the outdrive is an Alpha 1, and I have no idea (prop numbers are pretty corroded or covered) what prop is on it. I was hoping that there was information SOMEWHERE on what prop specs came from the factory........Bayliner sold tens of thousands of these things, but I can't find a factory spec anywhere....
rs1lollie
If I would guess on what prop you have on your boat I would say it is a 14.25x21 poss 14.25x19. I have a mercruiser 3.0L alpha 1 1800 maxum and I'm running a 14x20 Mercury alpha4 4blade prop. it gives me great hole shot, low plane speed and still running 43 mph @ 4800rpms
