I'm in dire need of help.
I possess a 8 hp nissan outboard motor, from around the 1990-1992 years.
The problem is that the motor starts very well, when keeping on single turns it works fine, when changing gear to front it works fine and when I get to the max or close to it, after 2-3 minutes it just stops and overheats. Lately we have changed the impeller in the water pomp, the water goes out fine from the side of the motor. from the backside, water comes out with steam.
What should I do to resolve the problem?
Thank you,
Thank you,
