  #1
Old October 4th, 2009, 03:09 PM
poloman poloman is offline
Post 115hp 1978 Evinrude spark plug stripped
I'm new here, but I think I have a problem, and I thank all for any and all help. I stripped the thread on 1 of the ports (upper right from the back). I've been reading some of the info, and I thought I would ask for some specifics. I am not a mechanic, so what are my options? 1) I've heard of 'thread chaser'- difficult? fix the problem? est'd cost if I DIY? 2) helicoil- need to remove head? is that difficult? est'd cost DIY? est cost if I take motor to a boat repair shop? fix the problem? 3) ???- what are my other options, and est $ to have done?? This is a great forum, and I thank you in advance for some help.
  #2
Old October 4th, 2009, 03:15 PM
wilde1j wilde1j is offline
Default Re: 115hp 1978 Evinrude spark plug stripped
Remove the head and take it to a machine shop to have Helicoil installed. Replace head using a new head gasket and torque head bolts acording to shop manual values and tightening sequence. Retorque after ~ 10 hours running time.
__________________
Jim
  #3
Old October 4th, 2009, 03:18 PM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Helicoil insert. Do it yourself or remove head and take to machine shop. Not an expensive repair.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #4
Old October 4th, 2009, 06:54 PM
thanks for the info- 1) is removing the head fairly straight-forward, or is there a list of 'do's and don't's'?? 2) what would be a fair price to pay at a machine shop or boat motor repair shop for them to install the helicoil?
  #5
Old October 4th, 2009, 07:09 PM
tx1961whaler tx1961whaler is offline
Removing the head is easy.
You have to get a new head gasket.
  #6
Old October 4th, 2009, 07:18 PM
kenmyfam's Avatar
I would do the job for under $50. It's 10 minutes work with the correct equipment. Head will come off easy. I always back the bolts off a little at a time till they are all loose in reverse order of tightening them but that's just me !
__________________
  #7
Old October 4th, 2009, 07:35 PM
No need to remove head cover (smaller cap screws); typically 10 head bolts get removed (remove spark plugs, clear any hoses and wiring first). Head will come off (sometimes it takes a little persuasion to pop it loose.
Take one spark plug to the machine shop with the head. Typically most shops will do the Helicoil for ~$25 and an auto machine shop will do fine as an alternative to a general machine shop.
Replacing the head will require several things
a) a new head gasket
b) install head dry (no sealers are needed)
c) Clean any gasket remains off head an block, being careful not to nick either surface
c) head bolts are tightened in a sequence, starting from the center, and working back and forth to alternate ends, using a torque wrench and working up to the final torque value in 5 ft lb increments to 18 to 20 FT-LBS.
Sequence is:
7 ....... 8
3 ....... 4
2 ....... 1
6 ....... 5
10...... 9
d) Retorque after ~ 10 hours running
__________________
Jim
  #8
Old October 4th, 2009, 08:34 PM
Post Re: 115hp 1978 Evinrude spark plug stripped
wow! You folks really mean business! I will be going up to my cabin at the end of the month and take a look at what you've all spelled out for me- the boat is stored for the winter, but I will do some checking around - maybe pull the head off (?) so that I can get at it in March- again, I really appreciate the help, and I will give an update after I finish up in the spring. Again, thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
stripped spark plug 25 hp evinrude dmorray Johnson & Evinrude Outboards 14 September 5th, 2009 11:19 PM
1978 55hp Evinrude spark plug gap? bigbill239 Johnson & Evinrude Outboards 1 July 19th, 2007 06:39 AM
Spark plug gap on 1978 35HP Evinrude BobRitter Johnson & Evinrude Outboards 2 March 28th, 2007 04:16 PM
'69 Evinrude 33HP: Stripped Spark Plug Hole i386 Johnson & Evinrude Outboards 29 September 27th, 2006 08:49 PM
1978 Evinrude 85HP Spark Plug Gap eickenberg Non-Repair Outboard Discussions 2 June 24th, 2005 09:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
