Hey guys. I was just wondering if I should leave my OB tilted up or down when the boat is parked in my driveway? Is there any benefit one way or the other? Thanks.
The manual for my 60hp Evinrude says to "store motor in the normal running position to ensure proper drainage of the motors cooling system".
Pooled water in the passages could do what water does when left stagnant, and I would think being vertical would be less strain on the mounting bracket linkages and pivots.
I'm glad someone asked this. I have always been told to leave the ob in up position, but this has been by my father-in-law, and he usually isn't right about much. So will take you guys word for it and run outside and tip mine down right now.
if you cannot store completely down. after use flushing the motor let it sit in the down position for about 15 minutes, you can even bump the motor over (do not start) to help get the water out of the power head. then raise the motor only as high as necessary.
