  #1
Old October 3rd, 2009, 06:47 PM
attml attml is offline
Default 2008 Yamaha 115hp four stroke electric prob
I have a 2008, 115hp 4 stroke yamaha outboard on my 19ft Key west. I am having issues getting it started and it appears to be electrical? We had the symptoms of a dead battery about a month ago. The old battery was over a year old so I went to BJ's and bought a comperable deep cycle marine battery. When we installed it the boat started fine and I ran it that weekend. The next weekend I took it out and it started again fine and I ran it that day and I had no issues. I went to start it the following weekend and it acted as if the battery was dead again. At that point I pulled the new battery off and brought it ashore and and hooked it up to the battery charger. The brand new battery started pulling a complete charge as if it was totally dead? I verified no lights or accesories were turned on in the boat. At that point I took the original battery(which had been charging for two weeks and was showing as fully charged on the battery charger) back out and installed it. The boat still acted as if it had a dead battery (would sluggishly turn over but not enough to start). I did not have a lot of time to fool with it last weekend so I figured I would try again today. I took the now fully recharged new battery back out to the boat and hooked it the the old battery via jumper cables and it still acts as if the battery is dead? I checked both batteries with a volt meter and both are fully charged. When I hooked the volt meter to the battery connections entering the motor itself it is showing full power at that point so I think I can safely say it is getting full juice to the motor. When raising and lowering the motor it now sees like it barely has enough juice to raise and lower the motor? If I have two fully charged batteries, nothing is turned on that would draw power and the motor won't crank and is acting like it isn't even getting enough juice to raise and lower the motor what is going on? Unfortunately I can't even get it to shore to take it to the shop at the moment! Any ideas would be grealy appreciated!
  #2
Old October 3rd, 2009, 08:10 PM
robert graham robert graham is offline
Smile Re: 2008 Yamaha 115hp four stroke electric prob
Maybe a weak, loose, bad ground connection. remove,check,clean, re-tighten all connections, battery cables, starter connections, etc. Good Luck!
  #3
Old October 3rd, 2009, 11:00 PM
Default Re: 2008 Yamaha 115hp four stroke electric prob
I have cleaned and tightened all of the connections on the battery end? The connections on the engine end are tight and look factory new with no corrosion at all? Needless to say this is killing me because the Bluefish and the Rockfish in the Chesapeake are going nuts right now!
  #4
Old October 3rd, 2009, 11:24 PM
KC4YIN's Avatar
KC4YIN KC4YIN is offline
If it's 2008 model it is still under warranty. If you are sure all connections are good I would take it in to the shop and let them check it out.
  #5
Old October 4th, 2009, 11:21 AM
rodbolt rodbolt is offline
hook your voltmeter to the engine block and the positive post on the battery, while reading the voltagfe have someone crank the engine.
if voltage drops below 10.5V go find the bad connection or cable.
do a forum search on voltage drop tests.
I have had a few this past month where the cable was tight on the block but the area between the lug and the block was burned and making poor contact.
  #6
Old October 4th, 2009, 11:14 PM
Checked and cleaned the connections at the engine. Found the block where the battery wires come out of the transom and connect to the battery wires go to the motor. I cleaned those terminals. Found the switch/ fuse in the center console and direct connected that connection to bypass that connection in case it was a bad switch/fuse. None of the above action had any affect on the problem at all. Every place I cleaned I measured to voltage with a volt meter and I am getting a full power measurement yet the motor won't barely turn over and now it barely has the power to raise or lower the motor?
Mark
  #7
Old October 5th, 2009, 05:42 PM
did you actually place the red lead on the solinoid post and the black lead on the engine block and while holding them in that position operate the device?
only way to test it is while operating the device.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hook up a tach to a 2008 25HP Yamaha 2 stroke Skidooosl Yamaha & Suzuki Outboards 2 May 27th, 2009 05:47 AM
2008 Yamaha 150 HP Four Stroke greg19662003 Yamaha & Suzuki Outboards 2 November 3rd, 2008 11:52 PM
2008 4 stroke 115hp not documented help rickhise Yamaha & Suzuki Outboards 2 August 19th, 2008 09:08 AM
Propeller 115hp 4 stroke 2008 Mercury HDBartman Prop Questions and Topics 3 February 4th, 2008 07:46 PM
2002 Yamaha 4-stroke 115hp DMBullock Yamaha & Suzuki Outboards 3 November 9th, 2007 08:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
