JonathanEngr
- Jun 10, 2009
- 66
I'm getting the new Mercury Classic (carbed) 90 HP two-stroke engine installed today, and plan to use the boat this weekend. I've talked to one boat mechanic (independent) and two dealers, and they each say something different. The mechanic says that the fuel/oil mixture needs to be adjusted for the first 50 hours, one dealer says to leave the adjustment at factory rec'd settings and just add additional oil to my gas tank (while also using the oil injection on the engine), and the other dealer says you don't have to do anything other than add the two-cycle oil to the oil injection unit on the engine. I googled the same topic, and same thing--lots of different recommendations. Can anyone say for certain what the best way to break this engine in would be? Also, should I limit my RPM's for the first few hours? Use regular/Plus/Premium gas? I just want to do this the right way. Thanks!
