Hello everyone,
I have a question about my outboard which is a 1983, 70 horsepower, model# J70ELCTE Johnson outboard. This motor was on a 16 foot tri-hull speed boat that I bought and removed it from and then it was removed and put on a 1991 Lowes's Pontoon boat model 202, 20 footer. When I put this motor on my pontoon boat and went to crank her over it was idling about 2,500 rpm's and I made sure that the remote control and the motor was in neutral before I put the cables on. So I had my friend come over and he looked at it and adjusted the metal small rod that connects between the throttle roller cam that opens and closes the carb butterflies to the piece that moves the, I think, the timing lever that moves underneath the flywheel and makes contact with the full timing advance rubber stop. So I am thinking maybe that that is what is causing my bogging/stalling issues going from idle to forward throttle. I have had the carbs off three different times and soaked them and blew them out with 120 psi compressed air pressure and installed new carb kits and gaskets but still does this and I also adjusted the floats parallel to the carb body as looking at the carb upside down. Now when I take off first time of the day it will take off great with GREAT throttle pickup but if I pull a tuber or run the boat motor for a little while when it gets up to normal operating temperature then that is when I will have bogging/stalling issues. What is that metal rod on the side of the motor between the carb throttle cam roller pickup and the timing lever piece do. now the carb butterflies are closed at idle/neutral and there is a little space between the roller and the throttle cam pickup piece. Also when we adjusted that metal rod it idled at between 800/900 rpm's in a trash can full of water really nicely but in the water after warming up a bit a little different. Let me know becuase I am racking my brain out trying to figure this out. I did order a service manual specific to y outboard and haven't used it yet becuase I am curentl deployed right now and want be back until January 2010. Thanks again for your help, Bob
