Hi , I'm working on my Dad's 1980 40 hp mercury outboard. It has been parked for the last 20 years. it fired right up but wasn't cooling. so I installed a new water pump repair kit and impeller. all of the old impeller blades had disintegrated or broken off and i managed to recover three of the blade ends and matched them to where they came from. as for the other three, I don't know where they are. the engine runs good, water streams from the tell tale hole, and water is blown out with the exhaust from the prop.
should i persevere with my search for the bits? I've read the other post on backflushing the system and I'm ok with that if it is necessary, but I'm not sure where the thermostat is.
any advice would be appreciated. Thank you.
