  #1
Old October 2nd, 2009, 12:30 AM
stylesabu stylesabu is offline
Default depth finder inside hull of aluminum boat
Anybody ever try to mount fishfinder inside hull of aluminum boat? I was thinking about cutting small hole in hull an mount the transmitter to a piece of thick plastic an securing it to the hull. I fish in a lake that is full of rocks, it would be nice to know where they were. Just an Idea
  #2
Old October 2nd, 2009, 03:24 AM
dan t. dan t. is offline
Default Re: depth finder inside hull of aluminum boat
probably would work,if you want to cut a hole in yourboat ,I wouldnt do it myself
__________________
motorsport is the most efficient method known to man of turning money into noise
  #3
Old October 2nd, 2009, 05:51 AM
fishrdan fishrdan is offline
Check this out
http://www.vexilar.com/pages/accesso...ducers_au.html
__________________
2001 Crestliner SuperHawk 1800, Mercruiser 140HP,,, rebuild in progress
2007 Tracker 1436 jon boat, 7.5HP Force
  #4
Old October 2nd, 2009, 08:32 AM
JB's Avatar
JB JB is offline
I have a problem with any sort of permanent mount of temporary gear on a boat.
All electronics are temporary. Very rarely does any SONAR, GPS, VHF, etc. last more than about 10 years before it is obsolete or broke. A permanently mounted transducer then becomes a wart on the nose of the boat.
__________________
RED SKY at night. . .
JB
  #5
Old October 2nd, 2009, 12:58 PM
imported_John_S imported_John_S is offline
Quote:
I agree with the others, and would never mount a transducer in this fashion on any of my boats. Along with what the others have said, this can make for complications when trailer loading/unloading, with go over bunks or wheels. While it can be mounted out of the way of these items, sometimes the boat dosn't always go on as straight as planned. Being on the underside will always have the potential of hitting something and possibly cause a leak.
As far as rocks, if you are using it to find potential fishing spots - OK. If you wanted it to prevent from hitting them, maybe not. Anything over a couple of MPH you would not be able to react in time to prevent from hitting.
  #6
Old October 2nd, 2009, 06:00 PM
Thanks for the responces, The fact that i wouldn't be able to react fast enough is good enough for me. Thanks for the link, fisherdan. it would still help on un charted waters
  #7
Old October 3rd, 2009, 09:23 PM
old boat 54 old boat 54 is offline
Try this : small coffee can or similar, and fill 3/4" full water. set in flat part of boat hull, and put transducer inside can, with some small weight to hold it in place at bottom of can. I did it with a small old portable flasher type unit and it worked. With the modern units, dont know how accurate, but it wont cost you anything to try it.
  #8
Old October 5th, 2009, 12:45 PM
dingbat's Avatar
dingbat dingbat is offline
Quote:
You guys need to move up to the 21st Century.
Some of the hottest transducers on the market are flush mount thru hulls. They protrude off the bottom less than 1/4" and have not problems sitting on a roller or a bunk. I’ve had one installed on my boat for over 2 years now and could not be happier
A little over kill for the OP but these things do exist and they work very very well.
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
  #9
Old October 5th, 2009, 02:08 PM
Maybe you can answer some 20th century questions:
- Are they available for ALL standard consumer grade FF, ie less than $1000 units?
- Given aluminum hull, do you use backer board with that transducer? Starboard epozied to the aluminum?
- Is a low-cost plug available so you don't have to sell it with the boat?
- For a V or mod-V bottom, how do you correct for the angle?
- What is the average cost? ie is it reasonable for consumer level?
- I think it will be a while before we see flush mount Side Imaging.
  #10
Old October 5th, 2009, 06:07 PM
dingbat's Avatar
[quote=imported_John_S;2360691]Maybe you can answer some 20th century questions:
There is nothing special or proprietary about a transducer. Airmar makes the transducers for most of the major players.
Quote:
- - Given aluminum hull, do you use backer board with that transducer? Starboard epozied to the aluminum?
No backers required. You can get the units is SS, Bronze or Plastic housings
Quote:
- - Is a low-cost plug available so you don't have to sell it with the boat??
No plugs. Why do you want to keep an old transducer? Good excuse for getting a better one for the new boat.
Quote:
- - For a V or mod-V bottom, how do you correct for the angle?
They make “tilted element” versions where the sensing element is mounted inside the housing at an angle. You buy the transducer that fits the deadrise of your boat
Quote:
- - What is the average cost? ie is it reasonable for consumer level??
Depends on what you call consumer level. They start @ $200 and go up to a little over $1200 for the dual beam 1KW units.
Quote:
- - I think it will be a while before we see flush mount Side Imaging.
Do a search on Furuno CH250 Searchlight Sonar
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
is this a good fish finder/ depth finder??? has alarm for the depth. dkorzun21 Boat Topics and Questions (not engine topics) 5 June 20th, 2009 07:41 PM
Mounting fish finder transducer inside hull of aluminum boat tuneball Electrics, Electronics and Trolling Motors 6 March 20th, 2009 10:54 PM
so if i mount a depth finder inside my hull? jake069 Boat Topics and Questions (not engine topics) 11 August 25th, 2006 04:47 PM
Condensation inside aluminum hull a problem? tony_cliffy Boat Topics and Questions (not engine topics) 1 August 27th, 2004 08:35 AM
Aluminum corrosion from inside hull turbot Boat Topics and Questions (not engine topics) 3 August 6th, 2004 05:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
