Re: prop pitch
If the boat is up to 15 feet long, start with a 10 3/8 diam X 13 pitch three blade prop. Over 15 feet, go to 10 3/8 X 11 or 12. These props are usually not available new, so look on ebay or go over to The Chrysler Crew and ask there.
Some marinas advertise on ebay and will sell new props (NOS New Old Stock, still in box) but they want a lot of money.
If you are lucky, you might find a used Bronze one which will look real nice on the lower unit.
These props used to be very common because they were used on Chrysler 35, 45, 55, and OMC 40-50 HP engines. The basic prop was the same but the rubber hub was different. Unfortunately, the hubs are no longer available so you can not buy an Evinrude prop and re-hub it.
The avatar in the upper corner is a nice little Chrysler 50 on a 10 foot tunnel hull. It is swinging a bronze two blade 10 1/2 X 14 cupped racing prop at somewhere around 5500 RPM and 41 MPH.
