  #1
Old September 30th, 2009, 06:41 PM
ba_50 ba_50 is offline
Default Evinrude superfast twin 7hp gearcase
This motor has the two line fuel system. The gear case was full of water and the bearing or seal on the back on prop shaft is beat up.
Do I turn it upside down and take the bottom cap off? Will anything fly out? How does that seal/bearing go in? Will a 1/2" socket go over the prop shaft or would it take a 3/4"? Thanks.
  #2
Old September 30th, 2009, 07:21 PM
Daviet Daviet is offline
Master Chief Petty Officer
Default Re: Evinrude superfast twin 7hp gearcase
If you are going to reseal the lower unit it needs to come off of the motor. There are other seals under the water pump and on the shift shaft that should be replaced also.
  #3
Old September 30th, 2009, 10:10 PM
samo_ott's Avatar
samo_ott samo_ott is offline
They never made a 7hp that I know of. What model # is it? It's on the transom mount. They come apart differently depending on the hp/model.
__________________
Steve.
  #4
Old October 1st, 2009, 12:42 PM
Actually I think it is a 7 1/2hp. I have another that looks just like it only I was told it is a 15hp. Strange they didn't put it on the cowling. Here's the numbers..
Evinrude superfast twin 7 ½ hp SN# 15012-44241
15hp 15012-47097
I've got the lower unit off and upside down in a vice. There wasn't any oil around the water pump, just the prop shaft. It looks like someone pounded the last piece rather badly and is probably the reason it leaks.
  #5
Old October 1st, 2009, 12:51 PM
rjezuit rjezuit is offline
From the S/N it's a 15hp, 1955 or 1954 I believe. Rick
  #6
Old October 1st, 2009, 01:00 PM
rjezuit is correct, 15012 = a 15 hp built in 1954,1955.
  #7
Old October 1st, 2009, 02:16 PM
R.Johnson R.Johnson is offline
The 7.5 was called a Fleetwin.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
72 evinrude 40 Horse "big twin" gearcase parts... jsbodies Johnson & Evinrude Outboards 6 August 31st, 2006 09:59 PM
Big Twin Gearcase Lube Question rennen Johnson & Evinrude Outboards 2 August 22nd, 2005 07:26 PM
1956 Evinrude 3hp ("Duck Twin") Twin questions felixwankel88 Johnson & Evinrude Outboards 14 April 25th, 2005 05:36 PM
3hp evinrude 1960's weedless gearcase of 90 deegree gearcase Tom987 Johnson & Evinrude Outboards 3 November 6th, 2004 10:43 AM
Carb for 1956 Evinrude Superfast Twin 7.5hp tsutter Johnson & Evinrude Outboards 3 June 11th, 2004 06:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
