  #1
Old September 30th, 2009, 05:53 PM
ziggy's Avatar
ziggy ziggy is offline
Default nineteen, 165hp L6 drain plug removal?
so has anyone removed their oil drain plug from a nineteen w/ the 165hp L6 engine in it? mine leaks and just looking at it, it looks like the drain plug don't have enough clearance from the inner liner to be removed so i can put a new seal on it w/o lifting the ft. of the engine. anyone with some insight for me?
__________________
'Lime Time'
1975 AristoCraft Nineteen
Mercruiser 165hp (chevy 250 L6), 1 drive
  #2
Old September 30th, 2009, 09:51 PM
GilliganBoat GilliganBoat is offline
Default Re: nineteen, 165hp L6 drain plug removal?
maybe you could try getting a rubber gasket and stretching it around/over the plug to get it where you need it....or.....maybe cut the proper gasket in order to get it around the plug, then cinch down nice and snug to get a good seal???? just some ideas. good luck, keep us posted.
  #3
Old October 1st, 2009, 09:56 AM
ziggy's Avatar
thanks for the ideas gb. i'd thought of the slice the seal and install idea and rejected it because my guess is that the fluid will find it's way to the slice and wick right past it resulting in still leaking.
the stretch a seal idea might be something to consider though. however my general notion is to do it right the first time, with the proper seal. i will let the board know what happens when i get that far...
fwiw. cool name man. gilligans island just happens to be my favorite tv show. i still watch it often on dvd..
__________________
'Lime Time'
  #4
Old October 6th, 2009, 06:24 PM
ziggy's Avatar
nope, i couldn't get the engine oil drain plug removed. not enough clearance. had to raise the ft. of the engine 3 full turns up on the adj. nut for the alignment... put it back where i found it. will still do a alignment to see where i'm at...
__________________
'Lime Time'
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercruiser Alpha One Drain Plug & Vent Plug davemoore Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 21st, 2009 09:44 PM
RDSL-22 Shift Plug (Oops not drain plug) jrpeterson75 Johnson & Evinrude Outboards 11 September 29th, 2008 12:41 PM
1977 Aristocraft Nineteen leaking at transom jacko137 Boat Restoration and Building 9 July 3rd, 2008 07:46 AM
nineteen review ziggy AristoCraft 9 March 10th, 2008 01:38 PM
OMC drive fill plug and drain plug> vonway Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 19 July 27th, 2005 03:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
