Hi folks, first off I'm new to boating and have limited working knowledge of engines, so please be gentle.
Here's my problem. I have a 1980 Searay with a 470 (or what's left of it) and just had the trim cylinders refurbished because they were pitted. Raising and lowering the drive worked fine for a couple of runs after I got it back, but then it would no longer lower.
Trying to raise the motor, you hear the relay click then the whirr of the pump. Trying to lower the motor, you just hear the relay, nothing else. Drive is in the fully raised position.
I noticed that on the bottom of the unit (has 79291a1 painted on the side, but I haven't been able to find what type of tilt unit it is), one of the connections was leaking fluid when trying to raise the motor. I tightened that and re-topped off the fluid, still same result.
Is there a way to:
A: Identify what type of power unit I have.
B: Troubleshoot the problem further.
I'm on a small isolated lake without a marina and since the drive is in the full up position it would take me a painful amount of time to limp it over to the boat launch and then trailer it an hour to the shop that just worked on it.
[Updated with link to picture of tilt unit]
Thanks
Is there a way to:
Thanks
