Hey everyone. It always gets to me when i'm reading a thread of interest and there is no finite resolution. Like people are getting close to a solution but you never know what the problem ended up being. So I am doing my part and following up with the results of my issue so... here it is... I hope you find it helpful.
My Motor - 1985 Mercury 90HP serial number "6436123 and up" which is the last model of this inline 6cyl made.
In August of 2009 I sold my 1982 75HP Evinrude and upgraded to a 1985 Merc 90 (inline 6 cyl) that had been in storage for eight years. I wanted more speed. When I picked up the motor I brought the following tools with me... A compression guage (loan a tool from O'Riley auto parts) and a metrinch tool kit. I wanted to hear the engine run and make sure every cylinder had good compression. When I arrived the owner had the motor hooked up to flusher and I was able to hear it run. It fired right up and idled well for a good 5 minutes or so. It also pumped water fine and the owner had a receipt for a brand new stator that had been installed by a dealer. I could see with the cowl off that the wires coming off the stator were indeed new. Not being an expert on outboards that was good enough for me.
So we take about 2-3 hours and install the motor on my boat using a "cherry picker" or engine hoist. The install went fine. Routing and hooking up wires and cables is the hardest part. I made sure marine grade silicone was used on the bolt holes, etc. So I get home and am anxious to take boat out and see what it will do. I have a 1982 Lund Super Pike that is in fantastic shape with a custom built windshield. The motor came with a 21 pitch prop which I was told was about right by a mechanic friend of mine. The boat maxed out at about 34 mph and only 4000 rpm. My heart sank... With the 75HP evinrude I got 35mph with a 17 pitch prop. Additionally, when in the water instead of on muffs the engine idled poorly and hesitated quite a bit on take off. It didn't seem to totally rev out and really sing. Not having a lot of money I ran it "as is" for the rest of the season. Over the winter I purchased a Seloc online service manual subsciption for my engine. Determined to get better performance out of the engine I took it out of storage today (it was 50 degrees here) and decided to do a full system check.
The compression was still great. It was between 140-145 on every cylinder. however when I pulled the plugs I noticed that the number 4 cylinder plug looked different from all the others. It looked new. It was the only plug that was bright white and all of the others were somewhat brownish with a bit of fuel residue on them. I called my mechanic friend and asked him about the condition of the plug. He is an older guy that actually used to race the early-mid 1980's era inline 6 cyl, 90HP Merc. He said they would get up to 6800 RPM out of them. According to him the plug condition was indicative of water getting into the cylinder and in many cases it happens due to some plate/cover in the exhaust manifold area. He said the plate in there can warp and allow water to leak into cylinders. Especially if the motor had sat for a while. My heart sank again... He said the way to test for water was to pull the plug on the suspicious cylinder and fire up the engine (no more than 1500 RPM while on the muffs/hose) and hold your hand about 4 inches from the hole. If water is getting into the cylinder there will be a water vapor coming out of the open spark plug hole. To my delight only air was coming out! Dry air! Next he advised that I check for spark and if there wasn't any it was probably a switchbox.
So, using my handy spark check tool, an inline type I got on ebay for about $3, I checked the #4 cylinder for spark and guess what? No spark! All of the other cylinders showed good spark. So I logon to seloc online and click to the ignition section of my online manual. It advised to test the systems in the following order using an ohm meter... Switchboxes, Stator Coil, Trigger Asssembly, and lastly Ignition Coils.
Step 1 - Switchboxes
According to the service manual you cannot perform an instrument test on the switchboxes. You can only swap them with a working switchbox and see if spark re-appears. On this engine there are two switchboxes (3 cylinders each) and all other cylinders had spark so I took the time to swap them around which took a little over an hour. There are 10 wires per switchbox and a 3/8 nut securing each one. Not to mention the little rubber boot covers on every single one. Oh, I should also mention that I took detailed digital photos of what the wiring looked like prior to taking anything apart. After the tedious process of switching the boxes the problem did NOTfollow the switchbox. Still no spark on the number 4 cylinder! So now I know both of my switchboxes are good as all of the other cylinders still had spark.
Step 2 - Stator Coil
Since I knew the stator was new and had been dealer installed I skipped this step and went right to the trigger assembly.
Step 3 - Trigger Assembly
Following the manual I followed the procedures and checked continuity using an ohm meter that I got at Harbor Freight tools for $5. The Trigger checked out fine. This was an easy process and took about 5 min.
Step 4 - Ignition Coils
I individually checked each of the 6 ignition coils and wa-la! The number 4 coil returned no reading. Like it was dead. All of the other coils returned a reading. Excited that I located the problem I took the time to remove the bottom coil cover (6 screws) and attach the #4 positive coil lead from the switchbox to the positive side of the number 5 coil and leave the number 5 switchbox positive coil lead wire unhooked. So essentially I was still running only 5 cylinders but now the number 4 cylinder should be firing and the number 5 cylinder would be dead because it wasn't connected. Wa-la! The number 4 cylinder now had spark. It was definitely a coil issue. So I ran down to one of the 5 marine dealers in our area that had a coil in stock. The coil was $37. I installed the coil per the instructions using the RTV sealant and tape, etc. I fired the motor up and it ran great. I noticed about a 200 RPM change in the idle speed. All 6 cylinders now had spark and all of the plugs also looked the same after I ran it for about 5 minutes. The engine also idled noteiceably smoother. I plan to take it out sometime this week and see what she will do.
All in all my mechanic buddy said the drag of the dead cylinder was more than likely the cause of the poor idle and poor overall performance. He said it's hard to hear on the inline 6 cyl if you're not trained for it because at idle they still sound pretty good even with one cylinder down. He also said that if top end performance is still poor then it's probably a fuel system issue or timing issue but timing is rarely an issue unless someone has tried to mess with it.
Another specific tip aobut this particular engine is NOT to idle them below 1300 RPM for any length of time like longer than 2-3 minutes. For whatever reason, even at 6800 RPM, these engines will still only generate 7lbs of pressure in the water cooling system. He said that because the water pressure on these motors is so low, idling the motor doesn't allow the water to fully reach and circulate around the top #1 piston. He said that if you watch your "pee stream" it will be kind of spitting when this condition exists. If you see the water outlet spitting like that increase your RPM's immediately until you see a constant stream.
Again I hope this post helps someone. I will post back within a week to report the test run results.
Thanks again for all the info I have found on this site.
