  #1
Old September 29th, 2009, 02:55 PM
Koosma Koosma is offline
Default 1999 Evinrude 15 hp 4 stroke
Hello everyone,
I am new to this form and have found some very helpful tips but nothing that gives any help with a problem I am currently experiencing.
I recently bought a 12 foot aluminum with a 1999 Evinrude 15 hp 4 stroke for fresh water exploration up here in Manitoba, Canada. I bought it from a roommate that used it here and there at his lake and thinks he only put about 40 hours on the motor from new. I trust his word and the motor also looks to tell the same story.
The motor when cold starts great with three pulls at full choke. It even stays idling right after (which is not as common with a cold start on a 2-stroke). If I desire to speed away with little warm up, I have to use partial choke to get past a dead spot in the throttle, and then she flys! To also note, it actually picks up speed at WOT if I use some of the choke. Then after about 7-10 min at max throttle (with or without the choke), the motor starts to sputter, misfire and pop like the sound of pop corn and then die. It now takes 5 or so pulls to start back up. Now that the engine is warm if I rev up the motor out of gear, it will do the same and die. Choke at this point does not help starting or keeping the motor running at WOT. It does however help with the dead spot (around 1/3 to 2/3 throttle) especially if I manually choke it by putting my hand over the air intake. I can troll for hours and the motor never misses a beat. Turns off like it should and on with one pull starts! I just can’t go faster than 1/3 throttle.
So far I have cleaned out the fuel tank and used fresh gas. I have also opened up the carb but found it very clean! As it was clean and I did not have any compressed air, I did not do anything to the jets. When driving, the primer bulb is always firm and squeezing it when the motor is acting up does not make a difference (it might hurt performance). From the word go, there is always a healthy stream of water flowing out of the motor.
Any advice or wisdom that can be offered would be greatly appreciated!
Thanks for your help
Darryl
  #2
Old September 29th, 2009, 03:27 PM
jeff_smith_0423 jeff_smith_0423 is offline
Default Re: 1999 Evinrude 15 hp 4 stroke
I would start with a true carb cleaning to rule it out. If i were you I would obtain a factory service manual for your motor - it's a rebadged suzuki. Generally recognized as pretty good motors. You may get more responses in the Suzuki forum as this area tends to be pretty 2stroke oriented.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 Evinrude 4-Stroke 15HP mtemple Johnson & Evinrude Outboards 3 May 22nd, 2007 11:08 PM
1999 Evinrude 5hp 4-stroke problem mykissmania Johnson & Evinrude Outboards 0 January 3rd, 2006 02:27 AM
1999 70 HP EVINRUDE 4-STROKE OIL LEVEL CHECKLIST Johnson & Evinrude Outboards 6 September 20th, 2004 08:09 PM
Smoke ? 1999 Evinrude 70 Four Stroke neumanns Johnson & Evinrude Outboards 2 July 24th, 2003 06:40 AM
1999 Evinrude 70 four stroke efi maintance sch. neumanns Johnson & Evinrude Outboards 8 March 2nd, 2003 06:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
