Does anyone have a good method for stopping galvanic corrosion on aluminum boat trailers? I have an aluminum trailer that is used exclusively for launching in salt water. The bolts are stainless and corrosion is taking place around the bolt holes. I use Corrosion X (green can for salt water use) with some success. Would replacing bolts with hot-dipped galvanized ones be a solution? Thanking you in advance for any advice you might have concerning this matter.
