belairbrian
- Aug 21, 2009
- 360
Boat will not idle.
Can get it to run with throttles open but lots of white smoke.
Pumping primer bulb has fuel coming from behind the throttle plates.
So I removed all 4 carbs and pumped the bulb still has fuel coming from behind the throttle plates.
Only thing I can think is there is an internal leak inside the pump between the pulse chamber and the gas chamber. Thus allowing gas to go back through the pulse house and into the engine.
Anyone think of another reason fuel can get behind the throttle plates?
