Hello there, im running a stealthdrive sd 46 on my kayak (3 1/2") hub, its a modded 46 thrust motorguide engine i think.
Its fitted with a motorguide machete III prop but i was thinking of trying a hydrilla hacker for greater top speed as this seems to be the only other prop i can find that would move more water.
All in all im thinking, as the kayak is light and the engine have limited rpm then a steeper prop would result in better speed and less battery use.
Am i all wrong on these things? also would the hydrilla hacker be too hard on the motor.
Hope someone can enlighten me.
Thank you very much
Thank you very much
