I'd like to soak but don't know how far up those elbows go. What is the preferred method ?
B bang4dabuck Petty Officer 1st Class Joined May 24, 2009 Messages 296 Aug 23, 2009 #1 I'd like to soak but don't know how far up those elbows go. What is the preferred method ?
H HybridMX6 Senior Chief Petty Officer Joined Oct 22, 2008 Messages 676 Aug 23, 2009 #2 Re: Carb soaking/cleaning - valve bowl(aluminum w/plastic elbows) What to do ? My manual for a 1993 60hp says not to soak them, but to simply clean all the passages and orifices with wire of something.
B bang4dabuck Petty Officer 1st Class Joined May 24, 2009 Messages 296 Aug 23, 2009 #3 Re: Carb soaking/cleaning - valve bowl(aluminum w/plastic elbows) What to do ? I guess then SOAKING is only for the carb body and all small parts. I am thinking tobacco pipe cleaner for cleaning out larger orifices and passages. Last edited: Aug 23, 2009
J japayton6 Cadet Joined Aug 23, 2009 Messages 25 Aug 23, 2009 #4 Re: Carb soaking/cleaning - valve bowl(aluminum w/plastic elbows) What to do ? I use piano wire or guitar string.
